Motherboard Battery Lifespan.
17 Oct 2002
Leeds
Hi there
I have Gigabyte Gaming X AM4 from 2019. Daily mild usage. But since July 2024 it has been completely unplugged by the power cord as I don’t have a GPU at the moment. When could the CMOS battery begin to lose power?
A good quality CR2032 battery is rated for about 10 years shelf-life, though the generic ones that come with a lot of hardware can be as little as 2 years. The current drain from the RTC and EEPROM or whatever implementation used should be low enough to keep settings for around 2.5 years or more (a good implementation on paper could maintain settings for about 20 years), in reality some boards are poorly implemented and have higher drain.
I had to change the one on my B450M Mortar Max after I'd left it a while. Bought that in 2019 too.
They do go.
Are these rechargeable that get power from the PC when it is on or are they just normal batteries that need replacing?
They don't recharge.
They are very low draw though, so basically the battery almost "goes off" before it's discharged as such.
They are cheap and easy to replace, although as above a good one should last about 10 years.
They do go.
Unfortunately it is a bit of a how long is a piece of string subject - I've fished 10-15 year old hardware (which uses a CR2032 battery for time/settings) out of my parent's loft and it has still retained settings, other times I've encountered systems which can't even do more than like 4 months. The implementation of the hardware and quality of the original battery (if not replaced) can make a huge difference.
Very much so.
My x58 board still had a working battery last time I booted it up (a few years back now but it was old - what was that, 2008/2009 ish release time?) so probably 10+ years.
I think Asus use low quality ones as both my Asus boards needed replacements after 2-3 years while my previous Gigabyte board went 9 years with no replacement required, current Gigabyte board is at 3 and current MSI board is 5 years old and going strong.
Lots of machines in the house for the me and kids, not a motherboard addict :D
Wouldn't surprise me - amongst other experiences with Asus I once bought one of their premium branded routers only for the power switch to fail after 1-2 years or so, opened it up and even the cheap Chinese knocks-offs of the latching PCB mount switch used are better quality... they always cheap out where they can.
Seems to be a common issue with ASUS. If i wasn't an SFF enthusiast it wouldn't be such an issue but disassembling a ITX motherboard to get to the battery is a royal PITA. Especially on the Crosshair VIII Impact.
