Motherboard bought from ebay has a bent pin, what to do?
15 Sep 2008
I bought a used Z97I motherboard from ebay (I know...) and it was sold as working etc, but me being me, I visually checked over the board before putting any components in it.
Yep, one bent or misaligned pin, here's the best macro shot I could get of it:
y4mH4hScXoA9UYbm6DAcEFshjTXlBc5j7a4jer4RqJr205bnUbVwmdBw9oedccISfTKWX7x8v5QwoJG3YkfuJxbf1q-UYf5fbuaAcyaafbov_FQkirGAwYQp0zrZI-Dtn9D1PsMZWVN8IAt9ZZIzqKyLIJZ99aVlwif4CcHTQ0L3Os
The landing pin is only a few degrees out of alignment or bent and it may go to it's correct position when the processor is fitted. Or it may not and totally miss the pad of the processor and/or short with the pin next to it.
The Intel datasheet gives the following information:
y4mXCjJKIA3owiBAqo_IQNMyV15u5R_DinzNTYxutWAZ8ARq0mZj3VboSRtfPCdoQgcnnto6gmLOyj615eLojrlH7Dx2dyxBpTH1-Zwynw-FUhHHq4dDmsZxEE-UF-WFGWNEoq7nrqdGYyqC_gPv4cV6JvcPwr3MC1U0vbHVBPamn4
The offending landing pad is AU40 and it may short with it's neighbour AU39.
AU40 is "VSS_NCTF" - Non-Critical to Function: These pins are for package mechanical reliability.
AU39 is "RSVD" - Reserved: All signals that are RSVD and RSVD_NCTF must be left unconnected on the board. Intel recommends that all RSVD_TP signals have via test points.
So that sounds promising, yeah? Yeah? Should I:
a. risk it for a biscuit as it is and just try it with my processor?
b. try and move the landing pad to a more aligned position?
c. send it back to the ebayer untried?
C. As someone who’s sold motherboards on eBay my advice would be to not touch it and to just return it. If that pin falls out or is repositioned, you’ve changed the product description and you won’t be eligible for a return.
I’ve had buyers knock capacitors/ cpu pins off motherboards, and haven’t been able to refund them.
Alternatively, you could ask the seller for permission to try option A or B via eBay messenger as this should offer you protection in a claim. I personally would go with C though.
If the end of the pin is bent down sharply then send it back but of its just stuck under the other pin then it doable.
Well, going by OP, the product description is working.
Thanks for the comments and suggestions. I decided to crack on and adjust it as I'm sure the landing pad was pretty redundant going from the Intel spec sheet. I didn't want to waste my time and that of the seller's, plus the waste of returning a perfectly good motherboard.
Here's a microscope image before before:
y4maCxCNgwaQ_yAMkdqF09OO13RFI80_tQD1rJsPNJfq2ad2iCDOvTMY7daeakzUOPjNGURqH_hE9NdjRhgc42BHWDmrYwfRZRjEt9S1xbrSpMCw2F7ITNR1Ge8FaJhNl25iNV-5b2OP2OHCY4G2Z5wde8vcfWnMm27HFgY5OWhNt0
And here's an image from after a little bit of gentle nudging with some fine tweezers.
y4m-xvzJOZEQQ9qvrmb1KVQhmJvSomOhjyj3iLaDa8oOL8uQtU2ffR_S2dm8_TY0Ct0xmIUwkFDNy0077c0weGADWciI4hMwjDEg2dw0NQ0HzjRsyPHk7NoRHA411fKVVpCHcuQuNi0iqnMAdLgljfI8Vc5SrY_IJnb_RLYgloe-ec
Sorted and no drama. In fact I'm posting this from that very same motherboard :).
