I have a question, are motherboards designed to flex or bend a small amount when installing?
I got a ASUS rampage 2 gene and installed it into its case, it does not have a hole for a screw near the panel connecter so that corner of the motherboard is not supported.
When i pushed the usb connecter into its space the motherboard flexed downwards at least half a centimeter which i thought was a bit much. Is this likely to have killed the motherboard?
I just completely forgot that there is no spacer in that part of the mobo![Eek! :eek: :eek:](/styles/default/xenforo/vbSmilies/Normal/eek.gif)
I dont have a way to test it as I am only getting the psu next week.
