Hi all,
Having some very frustrating mobo/cpu issues. I'm pretty green when it comes to this sort of thing, so the solution's most likely very simple, but thanks for taking the time to read this anyway.
So, I recently bought an MSI 945G-M4 Rev 1.0 mobo and an Intel C2D E6600 SL9S8 to pop in it (these are replaacements for my old asus mobo and intel cpu which were running Windows 7 from the hard drive - the same one I'm using in the new build). The only problem is that it doesn't work. No boot, nothing whatsoever except fans.
My old CPU works perfectly in it and I can access the BIOS etc so I can tinker about, but as soon as the new CPU is in there the system is dead as a door nail. I'm pretty certain it's not a CPU issue, as I've tried 3 of the same E6000 cpus in there and none worked. This CPU has been tested in a friend's machine and runs wonderfully. It's not a mobo issue, because I can use other CPUs in there.
I've tried flashing the BIOS but every time I try. I just get an error that reads: "ROM ID incorrect", which is strange because I've tried every possible combination and followed every tutorial and guide I can find and nothing seems to work.
Seriously spent hours and hours before finally resorting to coming on here and wasting all of your time.
Any help would be greatly appreciated as being painfully poor, this is my only machine.
If I've not provided enough info, let me know what you need to know and I'll try my best to answer.
Pure stress at this dead end.
