Motherboard Differences? (noob question lol)
11 Sep 2014
Suffolk, England
So, despite having built my own custom rig already before (twice in fact), I still don't know a huge amount on the tech spec side of things. I know the basics, but not a whole lot more. So my question is this; apart from the sizes, what's the difference between the range of Mobo's (itx, mini itx, mini atx, micro atx, atx, eatx etc). Like, are there differences in performance? quality? upgrade-ability/future-proofing? etc
I'm asking because my current build (currently in the planning stages) is ideally going to be a small rig in a custom built case, which sits on my desk. So a smaller board would be idea. Also, it'll be built as a gaming/streaming rig.
Thanks to anyone that can help :)
If you are looking at small, go for Mini ITX, they only have 1 PCI-E slot though, so no SLI/CF, or Micro ATX which some boards have 2 PCI-E slots, and a couple of x1 slots for Wireless cards etc. Then there is ATX which is the most common sized board, and E-ATX which is for workstations and bigger computers, only for much much higher end stuff. They go up in quality based on pricing, which is a good way to look, and depending on what socket you are looking at, some of the better boards that support Multi Sli/CF are quite pricey and expensive.
Hope this helps a bit
It depends on what you want out of the system, if you want expansion look at ATX or MATX boards.
Higher end boards have more features and overclocking options.
Thanks! I'm looking at the Asus X99M-WS, looks like a great board but it seems like it's built for a Micro ATX Workstation system. Would this be a good gaming board or not? I'm a graphics nerd, so the more performance I can get out of it the better, whilst keeping it as compact as possible!
