- 22 Jul 2004
The other night I installed a new Xonar D2X sound card along with its floppy power cable and plugged in the AC '97 audio front panel to the AAFP connector on my ASUS P8P67 Pro. I booted up successfully first time, but hadn't set the AAFP connector to AC '97 mode from its default of HD Audio mode in the BIOS. I completely forgot about this BIOS setting, and instead changed the mode over to AC'97 via the Realtek HD Audio Manager control panel which seemed to work regardless. After I moved my PC back into position after installing these components, my Corsair F120 SSD drive died (could be a coincidence) and my motherboard has a random delay before the power indicator blinks on and I am able to boot up. Sometimes it switches on straight away, other times a couple of seconds or anything up to 5 minutes. Once initialized, however, everything appears to be operating normally.
I have tried putting everything back to the way it was (except the SSD, which refuses to show up in the BIOS at all) to no avail.
Anyone have any idea what could be the root cause? My initial thought would be some sort of surge or overvolt protection is kicking in on the PSU, but I can't see any discrepancies there at a glance. Please don't tell me I have to take everything apart and put it back together again, the case is too darn cramped.
] have the red LEDs at start up to show if something is wrong, check those to see if its a component - maybe try one stick of RAM in each of the slots or something.
