Just purchased a Gigabyte 970A-UD3P AMD 970.
For some reasons my fans are not fluctuating depending on the temp of any of my components. The fans max speed that I have are 1600 rpm, yet for some reason they stay at 495-550. In my old motherboard they worked fine.
I can't find any options in the bios, and trying to change it manually in speedfan does nothing.
The only fan that does change luckily is the cpu.
Any help would be appreciated as I've tried everything.
