Motherboard fault code AE
1 Dec 2011
SW3
Just put a new system together, it is an 8700k, Z370 gaming 7, 32GB 3200MHz DDR4 memory, 2 x 980Ti, 500GB SSD and a 250GB M.2 SSD.
Pc switches on fine but I get no picture on my monitor and the motherboard fault code says AE.
It means Boot to Legacy OS but without any picture on the screen I can’t see what’s happening.
Standard procedure would be to remove everything from the system and just have the CPU and Memory installed and use onboard graphics to get it to boot?
I’ve cleared the CMOS and removed the battery but hasn’t helped.
I’ve also tried a DP cable and a HDMI cable in both the cards and using the onboard ports.
Everything was bought brand new sealed apart from the GPU’s.
Any help appreciated.
Try one stick of ram. AE can mean training is passed but memory can't run.
Obviously try single card in x8 and x16 slot.
