I have a ASUS Crosshair III with a AMD Phenom II X6 1055T OC
My problem is that after i stripped it down to re-cable everything to get a tidy system then fitted everything back in my computer will no longer post. On the LCD Poster it says "DET DRAM" so i stripped down everything again and put it all back together just in case i missed something, and still the same problem.
Reseated the CPU etc....
And still....
So i tried removeing all my RAM and placeing just 1 in on the DIMM slot 1 and everything worked, but once i removed it and placed it in DIMM slot 2 and slot 4 it doesn't post.
It post's perfect if there's RAM in slot 1 and slot 3 but not in slot 2 or 4....
Could this be a Motherboard at fault or the CPU becasue of the integrated memory controller? Memory seems to work fine.
I will say though, there is some little thermal paste on the CPU pins but I don't see how that can cause this problem. I have requested an RMA for the motherboard, but I'm also wondering if this could be the fault of the CPU as well maybe?
P.S Should i send both the CPU and Motherboard back for RMA just in case? Or can any of you experts know the problem that i could try?
Many thanks, and sorry for the really long post, If you need any more information, please ask.
And still....
