1 Aug 2017 at 18:15 #1 Dom86 Dom86 Associate Joined 27 May 2012 Posts 415 Hi I have a G3258 from a friend and I want to set up a cheap little gaming pc, what options do I have if I wanted to overclock it?
1 Aug 2017 at 18:20 #2 Minstadave Minstadave Caporegime Joined 8 Jan 2004 Posts 32,524 Location Rutland a lot of info here: https://forums.anandtech.com/thread...verclocking-enabled-for-pentium-3258.2389948/ Non-Z boards may have some limitations, my H81 board lets me adjust the multi but my max RAM speed is 1333mhz.
2 Aug 2017 at 14:02 #3 mistersprinkles mistersprinkles Associate Joined 21 Apr 2016 Posts 1,967 Location Oh Canada! Msi H81M-P33 is cheaper than chips and can run RAM at 1600Mhz. Used to build with them @ work all the time. Recommended. If you want something higher end the ASRock Z97-Anniversary was designed for the 3258 and is a great solid board, but costs more.
2 Aug 2017 at 20:09 #4 Dom86 Dom86 Associate OP Joined 27 May 2012 Posts 415 Thanks both of you, that helps a lot now to a source one.
