Hello, i have 2 graphics card, but this cards take all slots in my z87 gd65 gaming motherboard, any advice to change this motherboard for biggest solution?) because i wanna put sound and stream card inside, i need some space)))) thanks
What cards do you have? I have just looked through all the Z97 boards on OCUK and if your cards cover all your slots on the GD65 it's going to be the same with Z97.
You could try a riser card that plugs into the pci-e socket but don't use your 3rd 16x slot or your cards will run at 8x/4x.
Double slot cards then. You are going to be in the same situation with most, if not all the Z97 boards and only have the single x1 pci-e slot above the top card free. Look's like a riser card is your best option.
