Hello,
I was using my motherboard graphics for one monitor and my graphics card for the other.
Today I`m getting BSOB if I try use that port, tried many HDMI cables and a few different monitors but still the same. Wont even start up with the HDMI in that port.
Talking to the shop I got the MB from, the guy tells me its impossible to use that port if you have a graphics card connected, says the motherboard graphics port is disabled, why is this guy saying this, I just had the thing setup like that for the past month.
Did I not explain the issue right to him? I mean its simple really, when I use that port I get a BSOD
ASUS Sabertooth z77
I have taken the time to offer you advise and you have then incorrectly told told me everything I have explained to you is not true. If you come to our workshop I would still tell you the exact same thing.
It is not possible to run a monitor from your non integrated graphics card and integrated graphics card at the same time. “Other PC’s” would have have had a different chipset, your chipset and indeed any modern chipset does not support dual monitors between two differnt makes of graphics card/chip. If you wish to use multiple monitors they have to all be connected to the non integrated graphics card.
ASUS Sabertooth z77
