hi there.
i Recently decided to try and build my own computer, i put all my hardware in and to cut a long story short it won't switch on.
so i've gone back to the beginning. I know the motherboard works, or used to work because i only upgraded it back in march, i just decided to renew my case.psu, and graphics card. So anyway!, i took the motherboard out and connected my power supply to it, the 24 pin and 8 pin, i left the graphics card on and connected that up, but i can't seem to power it up. the motherboard i have is a Abit IP35 pro XE, there are two little buttons at the bottom, one says power, and the other says reset, but neither do anything, is there something i'm not doing?, any help would be great thanks
