I have all my parts to upgrade from AMD to Intel.
however.....
The AMD board is going into a 2nd build with the stock cooler, which means I need to put the 2 heatsink grips back onto the motherboard... these grips are what the stock heatsink clamp
onto...
My problem is that I think I may have lost 1 of the 4 screws.....
What's the best thing to do?
I'm putting my current 212 Evo
cooler onto my Intel rig.
Could I use the screws from the Intel Gigabyte board on my AMD Gigabyte board..
(I could just buy another hyper 212
Evo...but this was done on a very tight budget and i bought the CPU only (no HSF) as I was going to use the 212 Evo
NO MATTER I FOUND THE MISSING SCREW !!!!!
@FORUM MODERATOR
Can delete or lock this thread if need be
however.....
onto...
@FORUM MODERATOR
