Motherboard/Memory for i5 2500k
18 Sep 2008
Newark UK
Hi all,
I've decided to upgrade from a Q9550 to the i5 2500k. Main uses are for gaming and surfing. I may well run SLI or Crossfire at a later date so a board that has at least 2 fast graphics card slots with some cooling space between would be desirable
Can you recommend a Z68 motherboard for a budget of around £150. Initial temptation was with the Asrock Z68 Extreme4 Gen3...any good? Or is there something better for the money for my purposes? I'll go for 8GB of memory as well so if you can recommend some good memory for whatever motherboard I'd appreciate it.
Cheers. T9
Thats the board I went for, so hard to look past it really, slightly cheaper option would be this Gigabyte as its other I was considering
Re memory theyre all much of a muchness to an extent, PC 12800 is best bet for speed/price, something like the Corsair vengeance would match the mobo colours well, just be aware if you get the larger heatsink stuff it may conflict with bigger CPU cooler, if you get the low profile you wont have any issues
I'm in the same boat as you mate. Based on what I've read the Asus P8Z68 V Pro Gen3 (i.e. with PCI-e 3.0 support) is the best for around that price.
As far as memory, I'm probably going to go with the G.skill ripjaws for around £35 or the Kingston greys that are on offer at the mo' on OCUK.
Thanks for your thoughts guys. Looks like the Asrock could be a good choice. Didn't realise memory was so cheap at the moment so might stretch to 16GB.
Thanks again. :)
Yes, memory prices are cheap. But they will only get cheaper in time, you only need 4GB for gaming, and 8GB is still a good load. Personally id use that extra bit of cash to make sure your cooler and mobo and good for future upgrades. and get an SSD if you got enough money to spare. 16GB ram really isn't going to benefit you much.
Hi all,
Cheers. T9
I've gone for the Asus P8Z68-V PRO/GEN3 and 8Gb of Corsair Vengeance. Fingers crossed these are decent choices :)
Thanks Roverno. I have a crucial 64GB SSD for my OS but another would be nice for any games that might benefit. I have the Corsair H60 for cooling which I'm pretty happy with and I think will fit the i5 2500k. I was thinking of being able to run without a page drive with 16GB but as you say this may well be overkill.
