Motherboard Monitor and Fan settings
5 Jul 2005
Edinburgh
Using motherboard monitor with the data files from dfi street to get it to work with nf4. Having problems with the fan speeds. Have 2 vantec stealth 120mm fans that spin at around 1200rpm @12v and around 500rpm @5v.
The fan type is set as /1 and fan divider at 16 and that gives the right speed readings but when turned down to 5v the rpm suddenley jumps up well above the 12v rpm speed. Have tried increasing the fan divider but that hasnt helped. The weird thing is this is only on the exhaust fan and not the fan over the cpu. Also my ys-tech 80mm silent fan has the same problem.
any suggestions?
