I've just started building my first new rig in 12 years.
When I power up, the motherboard lights up the CPU LED, and then constantly toggles between the M_BIOS and B_BIOS LEDs every few seconds.
According to the manual, the CPU light means CPU is not functioning correctly. I've checked the CPU fan, which works properly, and I've tried re-seating the CPU - but no change.
No mention of the BIOS LEDs alternating, but my guess is that it's just a side effect of the CPU issue. (Main BIOS fails due to no CPU, fails over to backup BIOS, which also fails?)
My understanding is that it could be the motherboard that is faulty (e.g. bent pin) or the CPU. How do I know which component to RMA? Is it more likely to be the motherboard? Do you normally RMA both is this situation?
Any help gratefully received!
- Gigabyte Aorus GA-Z270X-Gaming 7 motherboard
- Intel 7700K
