Motherboard problem
8 Apr 2003
Hi guys hopefully one of you gurus can help
Got a machine been working fine now when i turn it on all lights up heard HD spinning etc but nothing on screen.
The only way i can get it to work is if I clear the CMOS (move jumper) it then works perfect until i shut it down then its back to clearing the CMOS or it wont work?
Replaced Battery
Power Supply
tried 3 seperate lots of memory
put new graphic card in
tried different HD and DVD Rom
does not appear to be overheating so this has me stumped??
Its on Vista at the minute if that helps.
Any help would be great
Mobo is an ECS socket 754 with Athlon 3400+ clawhammer on it.
