Hi, so basically I'm looking at getting either:
Asus Z87 MAXIMUS VI HERO Intel Z87 (Socket 1150) DDR3 ATX Motherboard
or
Gigabyte Z87X-UD4H Intel Z87 (Socket 1150) DDR3 ATX Motherboard
in the near future for a new build.
My question is, with a H100i cpu cooler (which I assume will plug into the CPU fan header) I want to add another 4 fans minimum to the case I will be getting, the Coolermaster cosmos 2. This case already has a 200mm front fan (which I may be replacing in the future), 2 fans on the bottom hard drive rack, and the rear exhaust fan. Is it possible to connect all of these fans to either of these motherboards?
I realise that the gigabyte has an extra fan header, but this still will not be sufficient for my needs.
I will also be running SLI 770's, so in terms of PCI slots, which motherboard would be better? Assuming they aren't the same and I'm just overlooking something.
If anyone has any idea how to solve / shed some light on this I would be grateful.
Cheers.
or
Cheers.
