My motherboard GIGABYTE GA-P35-DS3L went dead and was under warranty.
Unfortunately my retailer does not have a replacement board in stock but has an Abit IP35V Core 2 Quad. Is this a good replacement ?
Mfr Part Number: GA-P35-DS3L
CPU: Socket 775 Support Intel Core 2 Quad/ Core 2 Extreme/ Core 2 Duo/ Pentium Extreme/ Pentium D Processors; FSB 1333/1066/800 MHz
Chipset: Intel P35 & ICH9
Memory: 4x 240pin DDR2-1066/800/667 DIMMs, Dual Channel, Max Capacity 8GB
Slots: 1x PCI-Express x16 Slot; 3x PCI-Express x1 Slots; 3x PCI Slots
IDE/SATA: 1x ATA-133 Channel; 4x SATA2 Ports
Audio: ALC888 8-Channel High Definition Audio CODEC
LAN: RTL 8111B Gigabit Ethernet Controller
Ports: 12x USB 2.0 Ports (4 rear, 8 by headers); 2x PS/2 Ports; 1x Serial Port; 1x Parallel Port; 1x RJ45 LAN Port; 1x Coaxial S/PDIF Out; 1x Optical S/PDIF Out; Audio I/O Jacks
Power Connector: 1x 24pin Main Power; 1x 4pin CPU Power
Form Factor: ATX, 30.5 x 21 cm
Package: Retail
RoHS Compliant
Mfr Part Number: IP35V
CPU: Socket 775 Support Intel Core 2 Quad/ Core 2 Extreme/ Core 2 Duo/ Pentium Dual-Core Processor; FSB 1333/1066/800 MHz
Chipset: Intel P35 & ICH7
Memory: 4x 240pin DDR2-1066/800/667 DIMMs, Dual Channel, Non-ECC/Un-buffered, Max Capacity 8GB
Slots: 1x PCI-Express x16 Slot; 2x PCI-Express x1 Slots; 3x PCI Slots
IDE/SATA: 1x ATA-100 Channel; 4x SATA2 Ports
Audio: Integrated 7.1-Channel HD Audio CODEC
LAN: Integrated 10/100/1000 Gigabit Ethernet Controller
Ports: 8x USB 2.0 Ports (4 rear, 4 by headers); 2x IEEE 1394 Headers; 2x PS/2 Ports; 1x RJ45 LAN Port; Audio I/O Jacks
Package: Retail
RoHS Compliant
Package: Retail
RoHS Compliant
Package: Retail
RoHS Compliant
