Motherboard question??
You can use that.
1333MHz RAM speed is "overclocked" on that motherboard so you may have to do bit of fiddling in the BIOS to get it to that speed. Failing that it'll work at 1066MHz.
You can also use these which are £10 cheaper:
Corsair Value 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low Voltage Dual-Channel Kit, near enough the same
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit, faster RAM but you can run it at lower speeds
Edit:
You could have a gander in the MM and see if there are any DDR2 S775 motherboards for sale.
