Motherboard/RAM help?
25 Feb 2013
Current:
For this one? Gigabyte Motherboard Socket 775 P35C-DS3R S Series Intel Gaming
** link removed **
I don't really know much about them - but if you can help me out! I want a Motherboard that will help game play for Battlefield 3, and I don't really want to pay over £40, don't mind if it's second hand.
Also, I want to add some more RAM I was thinking about getting another 2GB stick, does it matter which I get as long as it's DDR2?
Thanks!
Current:
Thanks!
You would need another 775 socket motherboard, it is going to do you no real good upgrading the board and nothing else, 775 is also a dead socket. DDR2 ram is also dead tech but you can get some cheap, second hand. As long as it is the same frequency, i/e 800mhz you should be fine.
The only real benefit you can get is a GPU upgrade depending on what you have, even at that it might bottleneck.
What is your current cpu in your system?
Just doing to a Motherboard upgrade wont increase BF3, cpu along with the GPU will help greatly.
I've got a NVIDIA GeForce GT 320
That's the problem, upgrading the board will do nothing.
You are looking at upgrading that thing to at least a 7770 or a GTX470 but this depends on the CPU, since both these cards are low end-ish.
Being honest you are due an upgrade.
That build above will do just fine, capable of playing most games at medium settings, or this:
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor (AD580KWOHJBOX) £99.95
1 x Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard £64.99
1 x GeIL EVO Veloce Hot-Rod Red 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (GEV38GB2133C11DC) £47.99
Total : £223.73 (includes shipping : £9.00).
YOUR BASKET
Okay, thank you for your help! I'm going to need to Save for a new computer as I've spent my savings on a Car :)
no posting external sales links - id remove the link before a mod does it for you and warns you for it :)
look for the gigabyte z68 board in the B grade section on here. 35 quid. then pick up maybe 4gb ram. 20 quid. pentium 1155 processor. 30 quid. gpu, source externally, id recommend a 5770 (cheap, dx11) for around 45. 60gb ssd. 40ish. 400w psu. 30. antec merc alpha case. 30. Winner.
Is a 5770 worth it? Considering they go about £40-70 depending on where you look/luck, you could get an the 5800k with built in 6670 + the mobo for roughly the same price all in. Could reuse his old case as well if budget doesen't permit.
