Motherboard recommendation
4 Apr 2017
Hi,
I have an i7-6700 and 2x8gb PC3L-12800U ram modules from a stripped out PC which the existing Acer MOBO died.
It's been a while since I have purchased any PC components and looking for some recommendations on what MOBO I could get that is compatible with the i7 and 12800U RAM?
I am not looking to spend big money, it will be an HTPC system.
Cheers in advance.
Darren.
Gigabyte GA-H110M-DS2
http://www.******.com/782344-biostar-hi-fi-b150s1-intel-socket-1151-matx-motherboard-hi-fi-b150s1
Asus H110M-PLUS D3
Hi,
Cheers in advance.
Darren.
http://uk.gigabyte.com/Motherboard/GA-B150M-D3H-DDR3-rev-10#ov
http://uk.gigabyte.com/Motherboard/GA-B150M-DS3H-DDR3-rev-10#ov
http://uk.gigabyte.com/Motherboard/GA-B150M-HD3-DDR3-rev-10#ov
All support the DDR3 ram you've got , the H110M is DDR4 from a quick check.
All come with Gen 3 x4 M.2 slot so if you wish to get a very fast and fancy NVMe drive you can :)
Top two have 4 Ram slots if needs be
B150 Chipset bit more aimed with gaming in mind the H110 as you've got better onboard sound
