- 1 Apr 2014
Just completed a new 4770k build (see below) in a fractal design define mini case. Unfortunately, when I switch on,
Motherboard refuses to post & graphics/system fans fail to spin.
Checked cpu alignment & refitted using intel heatsink to ensure it wasn't an issue with third party zalman. Am convinced it's cpu
as psu & motherboard both switch on/light up. Is this likely? Any help would be appreciated. If I can avoid sending anything back, that would be great. Thanks guys!
System Spec:
Intel Core i7 4770k
Asus Maximus Gene Vi
Corsair Platinum 16 GB 2400mhz
Corsair 760w pro series
Fractal Design Define Mini Case
Radeon 4850
No SSDs fitted (build still in progress)
System Spec:
Intel Core i7 4770k
Radeon 4850
