Motherboard Replacement boot problems
31 Oct 2009
in the tower
Hi just upgraded my Motherboard (msi x570 gaming plus am4) i put it all together as my previous system but it gets stuck at the windows log on screen but i cant put my password in as it does not see my wireless keyboard)
Whats the best way or easiest way of doing this as its over 5 years since my last build and im getting old lol
any help
cheers
any help
cheers
Turn on legacy usb support in the bios I think is the way, I had this problem recently, I wanted to boot in safe mode but I couldn't press the 4 key to select safe mode.... Was annoying
Thanks but it wont see the keyboard so i cant boot into anything
Oh i Just read i can click on ease of access and bring up a virtual keyboard ;) i will try this later and i hope it works
Idk what to suggest,other than borrow another kb
Then once in bios do what illuminist said,youve tried each and every usb port on the mb?
Seemslike bios incompatibility with your kb,might work if you could update latest bios
Thanks i got a cheap wired keyboard but it was a fail in the end :confused: rma time (the last thing i need at this time of year lol)
I have read that some mobos are picky with USB keyboards
Have you tried the KB in ALL slots?
Thanks the wired keyboard works ok but on the dektop it just vanishes for a few seconds and come back with a crackling sound
it looks like a graphics fault but the card is a vega 56 which was working perfectly rma time and a wate of:confused: a weekend
