Motherboard Required
27 Jun 2016
Hi
Can anyone tell me where I can obtain in the UK an ASUS P8 Z77 - MPRO?
Will buy new or second hand. Tried eBay and all the usual suppliers but no luck.
Thanks for your help.
Rob
Due to forum rules even if there where any in stock anywhere we are not allowed to say where. Ebay is going to be your best bet really. As the socket is long dead now you won't find any decent boards brand new from any retailers. Just keep looking or do a forced upgrade.
Z77 boards price is off the roof really. Especially MATX and ITX.
Yep pretty much this.
I have a thread further down in this section asking for pretty much the same thing, I was looking for any overclockable 1155 mATX board and they are scarce and ridiculously overpriced.
In the end I just bit the bullet and bought an ATX Asus Z77 board which unfortunately meant also buying a new case to fit it in but the £135 spent on both the board and the case still made more financial sense than a full upgrade which would have meant a new mobo, RAM and CPU at a cost of over £400. Plus I should hopefully make a few bob back on my Q77m board and BitFenix case...
