Motherboard RGB isnt syncing up with my RGB strip lights, ideas?
14 Feb 2015
Scotland
Do you *definitely* have them plugged in the correct way? Some RGB software has checks to ensure that the RGB cables are wired correctly as RGB and not GRB, GBR etc etc
So i have the gigabyte cable coming off the motherboard, thats in the right way as it says what way to install it and that then is conected to my RGB strip, it only works one way, if i put it in the other i get nothing so it has to be the correct way, i guess i could flip the gigabyte plug but im sure its in the right way as it has the arrow.
Run through calibration option in Fusion ?
I have Phanteks digital and standard halo along with strimmer
Thanks, i didnt know there was a calibration option, its well hidden inside the slowest bit of crappy software ever, gigabyte really dont do software well huh? All good now though!
Yeah, I have issues sometimes with it . Pain when you do a custom colour, the. Want another part the same colour, can't enter in values or save it :(
