motherboard sata raid question
5 Sep 2009
im looking into a nas build. i will using the onboard sata. with intel it seems you have 2x 3g and 4x6g separate onboard chips where as amd you tend to get 6 x 6g
my question is can software raid work across both controllers on intel? same discs but different controller and drivers of course
iam planning a freenas ZFS build and would like the power & power saving of the ivybridge chipset but if amd works better using the single onboard sata then i will choose llano or trinity
thanks
