motherboard standoffs?
5 Sep 2011
Nottingham, UK
Where in all that is holy can I get motherboard standoffs from?
I am looking to take my case apart, clean it and replace the current crappy ones I am using, so I would like some shiny new ones!
I cannot find them on the OcUK website.
Help!
Thanks
Cinderz
non of them are the stand offs... just thumb screws... i need the ones that you screw into the case, then put the motherboard on top, then screw the normal screws into the stand offs
A well known high street electronics store which sells hi fi and PC components. Not sure how many clues I can give before I get banned, but a Google search for motherboard standoff should point you in the right direction ;)
You will probably get some fr with OCUK's cheapest case and it will be the same price as the highstreet for a little bag of 8.
Sorry not helpful.
You need to start a collect. I have a box in the loft the with all the screws from computers past. Means I can solve most things when I need to.
** The mentioning or hinting name of competitors is strictly prohibited - Please read FAQs regarding rules **
You know your breaking the rules else you wouldn't be making hints - Please don't!!
Edit:
Fair enough, my apologies.
*Don't test out patience*
