Motherboard temperature
11 Dec 2003
Hi guys,
I've just been checking out my motherboard temps and while gaming it can reach 48C, it usually idles around 42C.
I'm using a LianLi PC V2000A case with 2 fans (one blowing air in from the front over hard disks, other blowing air in from the back over CPU area). Both fans are running at very low speed using a fan controller to stop noise. The case itself has holes to dissipate heat out of the case.
Everything is very stable, no crashes, my E6600 idles around 32C with a Scythe Ninja cooler with a very low RPM fan.
Is the motherboard temp anything to be concerned about?
Thanks, appreciate any replies.
