This question does not only apply to my motherboard but is also a general query about increasing the number of motherboard usb pin connectors.
I've only got one set of usb pins (the row of 4 and 5 together) on my motherboard board but have bought an Akasa Allinone panel.
This panel requires 3 extra usb connections to the motherboard. One for the card reader and 2 for it's usb sockets.
Is there any internal hub or splitter cable available which will give me more motherboard usb pin connectors?
A bit of info on the Allinone:
http://www.pctechnology.gr/vbull/vb/printthread.php?t=20418
I'm hoping for a solution here but fear i may have to return the allinone unless there is some way round this problem.
(spec in sig)
m
(spec in sig)
m
