My computer has died so i'm looking for components to build a new one. My old system was a core 2 duo on a Asus DH Deluxe motherboard. The thing with that motherboard is that it had wireless built in and came with an aerial that sat on top of the case.
Due to the location of the computer I can only connect to my route via wifi so i'm looking at what my options are for this new system. Am I best purchasing another mb with built in wireless, if so does anyone have recommendations as there doesn't seem to be too many around? I will most likely be buying some kind of Intel i7 cpu.
Is there a better alternative to this? What about some kind of PCI wirless card, are these any good? If I was to consider something else it'd have to be reliable, I had no wireless problems with my old setup.
Thanks
Thanks
