Motherboard won’t power up unless I push it down on to the crypto mining chassis
28 May 2020
Hello,
Sorry for the long title.
I am having a rather weird issue which I assume has something to do with grounding?
I’m running a mining rig with a metal chassis. The system will not power up, unless I push quite firmly down on the motherboard where the main mobo power connector is and then it fires up and works until I let go.
I understand this is not good practise to do but does this explain what is causing the problem? I see sparks below the power connector underneath the mobo as it touches the chassis and everything powers up. Then I let go and it stops working.
Any ideas guys?
Kind Regards,
James
Here are some pictures. The rig, a picture of the main power connection and underneath if those silver pins touch the black metal chassis it works.
TH7mTY7
Bzfb5q0
3BDkySV
https://ibb.co/TH7mTY7
https://ibb.co/Bzfb5q0
https://ibb.co/3BDkySV
