- 11 Nov 2002
I was wondering if anyone knew of a resource that listed how many USB controllers you get on motherboards?
I was looking at setting up multiple webcams for a project and you can only really run a maximum of 2 USB 2.0 webcams per controller (unless you drop the res down a lot). I believe this is still the case even if using a USB 3.0 controller. There aren't really any USB 3 webcams available, certainly not at the prices of USB 2 ones.
None of the typical review sites or anywhere listing tech specs (even the manufacture) seems to list how many controllers there are.
It would seem that you typically get 3 controllers on most ATX desktop motherboards. Usually 2x USB2 and a USB3, or 2x USB3 and a USB2 on newer boards.
I'm not sure though if the USB 2 and 3 ports that come as part of intel chipsets count as one or two controllers? Anyone shed some light on this?
Now I can add more via expansion cards, was just wondering if there are any motherboards that have more controllers for future expansion.
