- 12 May 2011
- Southampton
I'm idly browsing TVs as I am wondering whether a solid 32" TV would make a good monitor. I see that TVs are described as having both a Motion Rate and a Processing Rate. If the Motion Rate is the Refresh rate, typically 60Hz for a basic TV or monitor, what is a Processing rate? Even if it is a BS number dreamed up by the manufacturer as a result of the TVs imaging processes, how does it actually work because surely the picture will be limited to the motion rate (e.g. 60Hz) as that is the slowest common denominator (kind of like playing a game at 100fps on a 60Hz screen, you're not going to see more than 60fps...)
Also how does Frame Rate come into this? I thought DVDs and TV was at 24fps anyway (not sure about BD) so why the very high 'refresh' rates?
Also do TVs have built in V-sync?
