I spend quite a lot of time trackside at Silverstone and it can be a bit challenging to find shots what with the porta loos, JCBs and busses etc. often trying to creep into the frame. There are specific gaps in the catch fencing around the circuit to allow spectators to get photos, off the top of my head there’s one on the exit of Becketts and at The Loop.
I often recommend to photographers in the grandstands to not solely go for the close up stuff, there are plenty of snappers trackside telling that story, you could try to get the wide shots incorporating the crowd and showing their reactions to events as well.
For the action stuff shoot in AI Servo mode, and my preference is for using the single centre point for focus, but it’s best to experiment and see what you like.
A common mistake often made is people panning at too low a shutter speed to start off with, start of high (around 1/250 1/320 or higher) depending on how close and the angle the bike is travelling through your panning range and get a nice shot, once you’ve got that then start experimenting and seeing how low you can go etc. Too many people start off super low and never even get a decent shot to record their day’s action. You may also need to go as high as 1/800 or higher if they’re coming towards you, many camera auto focus systems can really struggle with subjects moving quickly towards or away from them.
Another thing to consider is making a note of where the sun will be throughout the day and use it to your advantage, do you want to shoot into the sun or have it behind you? Having it behind you can light up the contrast points on the bike and make life easier for your focus system, but having it in front of you can make for some truly spectacular shots. Of course it could well be cloudy, but it’s an important thing to think about.
Finally, I’d recommend shooting the fast action in jpeg not raw with your particular camera. Some of the more affordable Canon cameras have very small image buffers and cannot cope with more than a few raw shots in a continuous shutter burst. There’s nothing worse than seeing a great shot appear in front of you, but you can’t do anything because your camera is still processing the previous images.
That’s all I can think of for right now, hope it helps and have fun
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
