Hi, I have a RAZR V3 which I can upgrade in April and I'm thinking of the above mentioned phone the A780 primarily because it has an integrated GPS antenna. My question is does anyone have this phone and whats it like.
I read somewhere that the satnav provided by ALK in the form of Co Pilot nav software for smartphones only supports a 5 digit UK post code? and as you all know UK post codes are 7 digit.
Cheers
edit: This phone has been in the UK since August last year and as I mentioned I would like to know if a 7 digit post is supported by the nav software
Ta
Cheers
Ta
