Motorola V525 prob
20 Jan 2005
Leeds/Oxford
Ear speaker has be getting worse and worse recently, not it has got to the point where i cannot hear a thing!
Is there anything i can have done to have it fixed? (how much?) Or am i best off flogging it and buying something new, if so what?
Yeah, mine went like that too - ended up just using a Bluetooth headset all the time....I'm not sure there's an easy fix for it and getting repaired probably not worth doing...
Thought that much :(
Seems a waste as apart from that its working fine (batt is going a bit aswell).
What would be suitable to replace it with? Would want normal things, camera and video would be nice. Something that looks pretty good and is fairly compact (but isn't going to break).
Thanks
Thanks
V3i/V3?
More of the same and V3 is silly money these days.
Otherwise I'd say 6230i is pretty decent for the money. If you can stretch the K750i is about £150(ish) and is pretty good.
