MOTs and Lights
  • Thread starter Thread starter box
  • Start date Start date
box
box
20 Nov 2005
Bristol
Very quick and specific question for you here....
<chav>
Will LED sidelights and painted-bulb headlights affect an MOT?
All bulbs burn white.
</chav>
Thanks guys
Provided they work, are the correct colour and point in the right direction, I see no reason why they would
If they are truly white, and don't have a strong coloured tint then they should be fine. What do you mean by "painted-bulb headlights" though? The ones with the blue filter on them?
led sidelights are fine, mine look a lot whiter than halogens....
painted bulb headlights may pass but they give out less lights due to the paint... :/
Yes, they have a blue filter on them.
Probably won't pass then.
I had some white LED sidelights in mine. They definitely didn't look blue and they were flagged up as being the wrong colour.
I liked it when the guy said "replace them with white bulbs". When did standard halogen sidelights look white?
Depends on the garage I've found
Standard halogen is warmer than white, if it fails he could just bung some cheapo £5 bulbs in there to pass the MOT then he can just switch back to his inferior filtered bulbs. ;)
I took this approach. It passed with the filter bulbs in thankfully. So all is well :)
