Does anyone make a bracket that I can use to get this rear light into a vertical position rather than be pointing up in the air?
I guess it would be something which I fix onto the seat stay and provides me a vertical support to mount the light on.
The light itself is a Moon Nebula.
As you can see, I don't have enough space under the saddle to put the light there because I only have little legs and am therefore a low down bum
Thanks.
Thanks.
