so i just bought a wireless xbox controller and the wireless reciever to play games like dark souls, DMC and so on
i dont really want to plug in the reciever and then unplug it when im done everytime i want to use the controller and i dont really want it plugged in all the time either so i had an idea and i would like to know from you guys if you think its possible
i have an unused USB 2.0 header on my motherboard so would it be possible to rewire the reciever so it can connect and be powered from the header? i would mount the reciever in one of my optical bays because its mesh so it wouldnt block the signal... the idea being whenever i want to use the controller i can just pick it up and turn it on the same way i would with an actual xbox 360 console
anyone think this is possible?
