I know the outside dimensions, i'm after all the smaller dimensions like the distance between two of the castor holes for 1 single castor, then the distance between one castor screw to the edge of the case and the distance from one castor mount point to another mount point.
Those sort of dimensions. I could measure the dimensions on my own case but it's all set up and running and very awkward to get too.
