I've bought a Desk Arm Mount for mounting my 24" DGM Monitor but i've stumbled upon a slight problem.
The holes at the back of the monitor are not threaded and the screws that came with the mount do not fit the holes (Slip right through them)
Now i was planning on going to any DIY shop i could find and just buy some self threading screws and have away with it, but my problem is Lans... i go to a lot of Lan around the UK and will be taking this beast with me and so i may need to be able to take it off and with it being using self threaded screws im not sure how well that will work :S
The mount did come with a adapter plate for 75mm to 100mm VESA mount holes and i was thinking of opening up the monitor and "no more nailing" this mount adapter to the back of the monitor on the inside so that i would have somewhere to screw the mount in and out of...
Argh... really dont know what to do, was looking forward to using this on a mount but looks like it might not happen now.
