- 22 Feb 2014
I intend to cut a fan sized hole in the bottom of a case, but do not want to mount a fan.
The reason is that this case sits inside a cupboard and I have already cut a hole in the bottom of the cupboard and put a fan in it, I want to sit the case over the top of this fan.
I would used a magnetic mesh filter, except the case is aluminium.
So is there a type of fitting that is commonly used for this purpose, without me resorting to a nut and bolt ?
I suppose I could take the fan out of the cupboard and fit it inside the case, though this will be difficult, given that the fan is screwed in from underneath said cupboard which is part of my TV unit which has all of my AV equipment in it.
