Hi all,
I'm trying to figure out a way to attach a monitor mount to a large wooden window sill.
Here is the location I'd like to fit it to:
I want to be able to lower the monitor down from the mount so that the bottom of the monitor actually sits below the window ledge itself, like this:
The problem is there is nowhere to attach a clamp to, and as I don't have access to the underside (because it sits on a wall), I cannot use a grommet type fixing either.
Initially I tried finding a mount that I can directly screw in from the top - but these seemingly don't exist.
Then I thought about using a bracket, similar to the below, but with a flat top, to screw into the windowsill (wood) and then clamp the mount onto it. But I'm even struggling to find a suitable bracket.
I've thought about using a freestanding mount but none seem suitable.
Has anyone here had a similar issue, or any ideas how to do this?
Thanks everyone
Thanks everyone
