So I've recently done a London to Amsterdam cycle tour. Throughout I used my action camera mounted to my helmet, but the straps are angled weird or don't go up as tight, and it wobbles a tad, and doesnt make the footage look good, also it weighs in a bit,so i can feel it on my neck from the weight over long periods.
It's the YI 4K Action camera, I haven't looked into chest mounting or handlebar mounting but what are your experiences? Which cam do you use, how do you mount it? Should I consider selling this and maybe going for the go pro action cams, the smaller block ones, seem lighter and easier to mount?
Any advice will be appreciated!
Planning a alps/Switzerland cycle next year
