Hi, I have two cantilever monitor mounted that I used in brick walls at our old house (we've just moved into a brand new build) and these walls are plaster.
I have two monitors that I wanted to mount, one in happy with because it's flat against the wall, however the other needs the arm to be extended to use it properly.
Will I be alright finding some kind of plaster toggle bolt or something to mount it? The mount is two vertical screws so the weight will be distributed vertically. I could get lucky with finding a stud.
Otherwise I'm tempted to just buy a dual arm desk clamp.
