I recently bought a considerably extended 1930s house (thick, previously external walls are now internal).
As well as cabling the house I need to sort the WiFi out. Mounting 1+ APs upstairs seems straightforward (run cable to the loft, install switch w. PoE, make holes in the ceiling and mount them) but downstairs I can't work out how to do them.
The original internal walls are single-layer block/brick and I haven't got into the ceiling void to see if there's gaps around ceiling joists to run cables through. Upstairs has tongue and groove laminate flooring, so a pain to get in that way.
How would you do it? Also, do the APs need to be on the ceiling, or would mounting vertically near the top of the wall also work?
Edit: I haven't got the hardware yet, so guessing how many APs I'll need for good coverage. Are there any apps to work this out first?
