Mounting hard disks in my TJ07
15 Nov 2007
Hertfordshire
I bought my TJ07 second hand about six months ago and there's literally nowhere to mount any hard disks. Since I got it, I've had the HDDs lose in the bottom of the case which is OK but not ideal.
I bought some of these:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-051-AK&groupid=701&catid=14&subcat=72
...intending to mount the disks in the 5.25'' bays but the drive bay covers get in the way.
Does anyone have any ideas how I could mount the disks?
How many drives ?
TJ07s' are massive plenty of room.
You could use the linked adapters and mount them vertically in the front bays by just using 1 set of bolts, for instance.
Just two; an SSD with a 3.5'' mouting kit and a standard SATA kit. I don't want to do any drilling or modding (no tools). I tried putting them in vertically but it doesn't give enough room for SATA data/power :(
