At the moment my fans are all in pull between radiator and case.
I am thinking about putting them in push so need to mount the radiator straight to the case.
I have a corsair 730t so it has rubber gromets on the top fan mounts.
Would 6-32 X 6mm be the right screws to go straight through to the radiator?
ie these. https://www.overclockers.co.uk/showproduct.php?prodid=WC-224-XS
Thanks
Thanks
